[多功能仪器] 钳形电流表校验装置
emhver 发表于 2009-3-7 18:11:24 | 显示全部楼层 |阅读模式
实验室里常用的fluke5500A coil 钳形电流表校验装置 如何校准?
请大家帮忙。
byang1997 发表于 2009-3-7 21:06:19 | 显示全部楼层
好象线圈 不用校准的。
bgqjm 发表于 2009-3-7 22:02:48 | 显示全部楼层
但是江苏省院要求校准,给出两个对应的电流值,我们也不知道他是如何校准的,估计是为了钱。
kou_247 发表于 2009-3-8 10:46:07 | 显示全部楼层
应该检定
我们送到北京上级计量机构,要求检定,给出的是测试报告!我认为线圈虽然是5500的附件,但它的比例值也是一项重要指标,应该检定
风吹石 发表于 2009-3-8 11:20:25 | 显示全部楼层
回复 4# kou_247 的帖子
既然是测试报告,如果有源和表的话,为何自己不能测要送检呢?
byang1997 发表于 2009-3-8 13:28:06 | 显示全部楼层
个人认为, 只要数数是不是50匝,表面有没有损坏,这就可以了。
这东西本身并不影响输出精度。只是把电流感应放大而已。
你只要保证你的源是准确的就行啦。
个人观点, 仅供参考!
The 50 Turn 5500A/COIL is used as a tool for calibrating clamp type current meters that operate by two different principles ¾ as current transformers (AC only), and by the Hall Effect (Both AC and DC). It is impractical to calibrate 1000A rated current clamp meters using a 1000A source. However, by using the 50 turns of the 5500A/COIL in conjunction with a current calibrator you can effectively multiply the current of the current calibrator by a factor of 50 to support the calibration and verification of these clamp-on current meters.
General Specifications
Number of Turns
50
Maximum Current
11A rms, continuous
20A rms, 2 minutes
Maximum Duty Cycle Derating
< 11A, continuous
> 11A, 2 minutes ON, 8 minutes OFF
Maximum Voltage
3V rms
Frequency of Operation
DC, 45-440 Hz (should not exceed rms Voltage rating)
For the 5500A Current Output:DC, 45-65 Hz, 0-11A
65-440 Hz, 0-2.19999A
For the 5520A Current Output: DC, 45-65 Hz, 0-20A
65-440 Hz, 0-2.99999A
This specification assumes that a Fluke 80i-600 Clamp Meter or equivalent is attached. Other clamp meters may limit the 5500A/5520A Current Output drive capability to less than the above.
Uncertainty Due to Clamp Meter/Coil Interaction
± (0.25% of effective output + 0.5A), for toroidal-wound current clamps, such as the Fluke 80I and 80I-1000.
± (0.50% of effective output + 0.5A), for current clamps like the Fluke 80i-kw, 80i-400, 80i-410, 80i-500, 80i-1010, Fluke 31, Fluke 33, or equivalent.
Minimum Inside Diameter of Clamp Jaws
2.54 cm (1 in.)
[ 本帖最后由 byang1997 于 2009-3-8 22:04 编辑 ]
huwenjing 发表于 2009-3-8 18:25:59 | 显示全部楼层
本人认为其最多在验收时检定一下,看是不是50匝,后期使用如果没有问题就应该是对的,其匝数不可能随时变化。
 楼主| emhver 发表于 2009-3-8 19:23:58 | 显示全部楼层
回复 4# kou_247 的帖子
出检定报告是需要有相应的检定规程的
线圈不是互感器,没有对应的1次和2次,无法参照互感器的规程来检定
线圈其实是作为扩展量程来使用的,即在小电流下面来校验钳形表的大电流量程
线圈本身匝数的分布和结构均会影响到钳形表的校准
因此需要校准线圈,否则如何进行钳形表不确定度的评定呢
请问对于线圈证书报告上是用什么标准器来进行校准、用的又是什么方法的呢?
礼匪 发表于 2009-3-8 19:31:06 | 显示全部楼层
原帖由 bgqjm 于 2009-3-7 22:02 发表
拿到报告打电话去问啊,再查查他们的能力资质
礼匪 发表于 2009-3-8 19:32:10 | 显示全部楼层
原帖由 emhver 于 2009-3-8 19:23 发表
出检定报告是需要有相应的检定规程的
线圈本身匝数的分布和结构均会影响到钳 ...
原厂只笼统的说了个偶合误差好象
李逍遥 发表于 2009-3-8 20:42:17 | 显示全部楼层
我问过上级计量单位,说线圈只需出厂是验收就可以了
 楼主| emhver 发表于 2009-3-8 20:50:36 | 显示全部楼层
出场是如何验收的呢
bgqjm 发表于 2009-3-8 21:00:00 | 显示全部楼层
关于线圈,我觉得它出厂后,相关的指标就几乎不再变动了,形状不会改变,匝数不会改变,线圈分布状况也不会变,那还有哪变,检定或者校准的意义在哪。
 楼主| emhver 发表于 2009-3-8 21:06:59 | 显示全部楼层
原帖由 bgqjm 于 2009-3-8 21:00 发表
关于线圈,我觉得它出厂后,相关的指标就几乎不再变动了,形状不会改变,匝数不会改变,线圈分布状况也不会变,那还有哪变,检定或者校准的意义在哪。 ...
其实互感器的结构也是线圈,但是互感器出场以后,结构也就固定了,那么是否互感器就无需检定了呢
互感器可是国家明文规定的强检器具。
秋实 发表于 2009-3-8 22:28:40 | 显示全部楼层
这东西我们的也是免校的,还真没细想过为什么不用校准。
在实际使用中因为那个线圈直径大过某些小型钳表,我们甚至自已用细线绕几匝去校准它,却不知这样有没有问题......
dingding_ll 发表于 2009-3-9 15:27:14 | 显示全部楼层
回复 1# emhver 的帖子
在江苏的都碰到这个问题,钳型表建标都要求检线圈的,可是没地方能检定的(没规程),我个人也同意版主的意见,数数是不是50匝就行了。
量院高才生 发表于 2009-3-9 19:24:20 | 显示全部楼层
我们的也没有校的,就开始买来的时候数数圈数,试用一段时间OK就验收了
bgqjm 发表于 2009-3-9 21:38:03 | 显示全部楼层
回14楼,互感器检定是检定他的比差和相差,而线圈不知道他检定的是啥指标,问他也回答不清,给我们的数据也就两个值,一个所谓的标准电流值,再一个我们的显示值,我不知道我们的显示值他是如何的得到。
 楼主| emhver 发表于 2009-3-9 22:37:24 | 显示全部楼层
回复 18# bgqjm 的帖子
这个线圈和互感器确实不一样,它没有一次和二次,所以不能象互感器一样检定其比差和角差
但是用线圈检定钳形表时和互感器又有相似之处
在检定大电流时,如果电流源无法产生足够大的电流时,可用等安匝法检定
钳形表就是一台互感器,线圈是穿过钳形表的一次母线
对线圈的校准实际是校准母线,也就是评估母线穿心的匝数和结构对钳形表的影响
我知道有些地方校准是加标准源,输出再用钳形表读数
用来校准钳形表的标准反而又用钳形表来校准,这样就成了鸡生蛋、蛋生鸡了
你可以再和江苏院沟通一下,他们的输出值到底指什么?
[ 本帖最后由 duomeiti 于 2009-3-9 23:08 编辑 ]
红山石 发表于 2009-3-17 22:00:15 | 显示全部楼层
钳形表校准规范中也推荐了使用“安匝法”,但是也没有说明对于线圈的要求,个人理解只要匝数准确且线圈的几何尺寸符合0.5米就应该可以的。
GMT+8, 2026-4-6 10:48
