[热电偶/热电阻/膨胀] HVI恒温恒湿实验室验收测试方法研究
上帝 发表于 2009-3-28 23:36:06 | 显示全部楼层 |阅读模式
武春爱 盛高珊 孟宪罗
河北省气象技术装备中心,河北石家庄050021
摘 要:探讨了HVI恒温恒湿实验室在质量验收中如何引用规范、测试标准器的选用、测试方法以及测试结果的数据处理等,以确定一个更适宜的测试方法实现对恒温恒湿实验室的验收。HVI实验室属高精度恒温恒湿实验室,其建设的技术含量很高,难度较大,不同的测试方法可能会有不同的测试结果,适宜的验收方法是建设质量评估的关键。[著者文摘]
Study on test method for acceptance checking of HVI constant temperature and humidity laboratoryWU Chun-ai, SHENG Gao-shan, MENG Xian-luo Hebei Weather Technique Material Center,Shijiazhuang 050021,ChinaAbstract:In order to determine the best suitable test method in the quality approval process of the HVI constant temperature constant humidity laboratory, the authors have discussed ways on how to quote the standards and how to select the test standard, the test method, as well as how to process the data of the test results and so on. The HVI laboratory is a high accuracy, constant temperature, and constant humidity laboratory. Due to its high technical content and technical difficulty in its construction, different test methods could possibly give very different test result, thus the finding of a suitable approval method is the key to build a better quality appraisal procedure.[著者文摘]
Key words:HVI; Constant temperature constant humidity; Test method; Check; Investigation
HVI恒温恒湿实验室验收测试方法研究.pdf
174.76 KB, 下载次数: 23, 下载积分: 金币 -1
GMT+8, 2026-4-6 21:33
