[磁参数和材料] 电工钢片磁性的计量问题
酱里个酱 发表于 2009-4-18 09:45:45 | 显示全部楼层 |阅读模式
JohannesSievert[1] 刘亚丕[2](翻译)
[1]德国联邦物理技术研究院,德国布伦瑞克 [2]中国计量学院摘 要:综述了电工钢片计量的当前水平和最新进展,重点讨论了在交变场中的标准测试方法:Epstein方圈法和单片(SST)法.所讨论的相关条款是有关磁通密度控制、数据获取和数据计算的最新电子方法,以及磁路设计对这两种方法的准确性和精度特性的影响,也讨论了系统误差来源、再现特性和经济因素等.[著者文摘]
On the metrology of magnetic properties of the electrical sheet steelJohannes Sievert Physikalisch-Technische Bundesanstalt, Braunschweig, GermanyAbstract:A survey was given of the latest development and the state of the art of electrical sheet steel metrology. It was focused on the standard measurement methods in alternating magnetic fields, the Epstein- and the Single Sheet-Tester (SST) Methods. The relevant items to be considered in this context are up-to-date electronic methods for the flux density control, data acquisition and data evaluation, and the influence of the magnetic circuit design on the accuracy and precision characteristics of the two methods. This included the consideration of the systematic error sources, reproducibility characteristics and economic aspects.[著者文摘]
Key words:electrical sheet steel; magnetic properties; metrology
电工钢片磁性的计量问题.pdf
330.35 KB, 下载次数: 11, 下载积分: 金币 -1
GMT+8, 2026-4-6 13:03
