[通用量具] 量具、量仪中英文对照
xgxm 发表于 2009-4-30 14:22:44 | 显示全部楼层 |阅读模式
量具、量仪中英文对照
1.刀口型直尺:knife straigjht edge
2.
刀口尺
: knife straigjht edge
3.
三棱尺
three edges straigjht edge
4.
四棱尺
four edges straigjht edge
5.
条式和框式水平仪
  bar form and square levels
6.
合像水平仪
imaging level meter
7
铸铁平板
cast iron surface plate
8.
岩石平板
granite surface plate
9.
铸铁平尺
cast iron straigjht edge
10.
钢平尺和岩石平尺
  steel and granite straigjht edge
11.
圆度仪
roundness measuring instrument
12.
电子水平仪
electronic level meter
13.
表面粗糙度比较样块铸造表面
roughness comparison specimens cast surface
14.
表面粗糙度比较样块磨、车、铣、插及刨加工表面
roughness comparison specimens-ground,turned,bored,milled,shape and planed
15.
表面粗糙度比较样块电火花加工表面
roughness comparison specimens spark-erostion machining surfaces
16.
表面粗糙度比较样块抛光加工表面
roughness comparison specimens pollshed surfaces
17.
接触式仪器的标称特性
18.轮廓profiles
19.
轨迹轮廓
traced profile
20.
基准轮廓
reference profile
21.
总轮廓
total profile
22.
原始轮廓
primary profile
23.
残余轮廓
residual profile
24.
触针式仪器
stylus instrument
25.
感应位移数字存储触针式量仪
displacement sensitive,digitally storing stylus instrument
26.
触针式仪器的部件
stylus instrument components
27.
测量环
measurement loop
28.
导向基准
renfence guide
29.
驱动器
drive unit
30.
测头(传感器
)probe(pick-up)
31.
拾取单元
tracing element
32.
针尖
stylus tip
33.
转换器
transducer
34.
放大器
amplifier
35.
/数转换器
analog-to-digital converter
36.
数据输入
data input
37.
数据输出
data output
38.
轮廓滤波和评定
profile filtering and evaluation
39.
轮廓记录器
profile recorder
40.
仪器的计量特性
metrological characteristics of the instrument
41.
静测力的变化
change of static measuring force
42.
静态测力
43.
动态测量力
dynamic measuring force
44.
滞后
hysteresis
45.
测头的测量范围
transmission function for the sine waves
46.
仪器的测量范围
measuring range of the instrument
47.
模数转换器的量化步距
quantization step of the ADC
48.
仪器分辨力
instrument resolution
49.
量程分辨力比
range-to-resolution ratio
50.
测头线性偏差
probe linearity deviation
51.
短波传输界限
short-wave transmission limitation
52.
轮廓垂直成分传输 vertical profile component transmission
53表面粗糙度比较样块抛丸、喷砂加工表面 roughness comparison specimens shot blasted and blasted surfaces
54
产品结构几何量计术规范(GPS
geometrical product specifications(GPS)
55
表面结构
surface texture
56
接触式仪器的标称特性
nominal characteristics of contact instruments
57
公法线千分尺
micrometer for mearsuring root tangent lenghths of gear teeth
58
最大允许误差
maximum permissible error
59
圆柱直齿渐开线花键量规
gauges for straight cylindrical involute splines
60
齿厚游标卡尺
Gear tooth vernier calipers
61
齿轮渐开线样板
the involute master of gear
62
齿轮螺旋线样板
the helix master of gear
63
矩形花键量规
gauges for straight –sided splines
64
测量蜗杆
master worm
65
万能测齿仪
universal gear measuring instrument
66
万能渐开线检查仪
universal involute measuring instrument
67
齿轮齿距测量仪
gear circular pictch measuring instrument
68
万能齿轮测量机
Universal gear measuring machine
69
齿轮螺旋线测量仪
gear helix measuring instrument
70
便携式齿轮齿距测量仪
manual gear circular pitch measuring instrument
71
便携式齿轮基节测量仪
manual gear base pitch measuring instrument
72
立式滚刀测量仪
vertical hob measuring instrument
73
齿轮双面啮合综合测量仪
Gear dual-flank measuring instrument
74
齿轮单面啮合整体误差测量仪
Gear single-flank meshing integrated error measuring instrument
75
梯形螺纹量规
gauges for metric trapezoidal screw threads
76
工作螺纹量规
work gauges for metric trapezoidal screw threads
77
校对螺纹量规
check gauges for metric trapezoidal screw threads
78.
梯形螺纹量规型式与尺寸
Types and dimensions of metric trapezoidal screw threads
79.
普通螺纹量规型式与尺寸
Types and dimensions of gauges purpose screw threads
80.
非螺纹密封的管螺纹量规
Gauges for pipe threads prcessure-tight joints are not made on the threads
81.
螺纹千分尺
Screw thread micrometer
82.
最大允许误差
83.
间隙螺纹量规
Clearance screw gauge
84.
量针
Bar gauge
85.
螺纹样板
Screw thread template
86.
用螺纹密封的管螺纹量规
Gauges for pipe threads where pressure-tight joints are made on the threads
87.
刀具预调测量仪精度
Accuracy of the presetting instrument
88.
薄膜式气动量仪
Membrane type pneumatic measuring instrument
89.
光栅线位移测量系统
Grating linear displacement measuring system
90.
光栅角位移测量系统
Grating angular displacement measuring system
91.
磁栅线位移测量系统
Magnet-grid linear displacement measuring system
92.
量块附件
Accessories for gauge blocks
93.V
形架
Vee blocks
94.
比较仪座
Comparator stand
95.
磁性表座
Magnetic stand
96.
万能表座 Universal stand for dial indicator
量具、量仪中英文对照.rar
5.12 KB, 下载次数: 36, 下载积分: 金币 -1
参与人数 1金币 +5 收起 理由
duomeiti + 5 谢谢提供
GMT+8, 2026-4-9 18:42
