[质量体系与标准] 关于UL对设备校准的15点要求,需哪位帮我翻译一下,谢谢!
jasonhuang 发表于 2009-6-30 11:29:39 | 显示全部楼层 |阅读模式
1. a title (e.g. “Calibration Certificate”);
2. the name and address of the laboratory, and the location where
the calibrations were carried out, if different from the address of
the laboratory;
3. Unique identification of the calibration certificate (such as the
serial number). Each page of supporting data requires an
identification to ensure that the page is recognized as a part of the
calibration certificate package. A clearly identified end of the
calibration certificate package must be labeled;
4. the name and address of the customer;
5. identification of the method used;
6. a description of the condition of and unambiguous identification of
the item(s) tested or calibrated;
7. the date of receipt of the calibration item(s) if this is critical to the
validity and application of the results and the date(s) of
performance of the calibration;
8. reference to the sampling plan and procedures used by the
laboratory or other bodies if these are relevant to the validity or
application of the results;
9. the calibration results with the units of measurement, where
appropriate,;
10. the name(s), functions(s) and signature(s) or equivalent
identification of person(s) authorizing the calibration certificate;
11. where relevant, a statement to the effect that the results relate
only to the items calibrated;
12. the conditions (e.g. environmental) under which the calibrations
were made that have an influence on the measurement results;
13. the uncertainty of measurement and/or a statement of compliance
with an identified metrological specification or clauses;
14. evidence that the measurements are traceable (to national
standards)
15. A valid accreditation body endorsement for the calibrations
performed (refer to example list of accreditation endorsements
below).
vandyke 发表于 2009-6-30 12:39:17 | 显示全部楼层
1、标题(如:校准证书)
2、实验室的名称和地址。若进行校准的地点与实验室所在地不符,还应注明校准地点
3、校准证书的唯一性标识。(如序列号)。每一页都应有标识表明其是校准证书的一部分。证书的结尾应有明确标记。
4、客户名称和地址
5、校准依据
下面大家接龙
美华 发表于 2009-7-1 09:09:30 | 显示全部楼层
这些都是17025规定的校准实验室出具报告的基本要求。不过我看到的版本和你的不一样,是将第15条列为第一条,其他的按序顺延。按你提供的翻译如下。
1.标题(例如,校准证书)
2.校准实验室的名称和地址,进行校准的地点(如果与实验室的地址不同)
3.校准证书的唯一性标识(如序列号)和每一页上的标识,以确保能够识别该页是属于校准证书的一部分,以及表明校准证书结束的清晰标识。
4.客户的名称和地址
5.所使用的方法的识别(通常有本次校准引用的技术文件栏,一般是JJG和JJF开头的计量检定规程和计量校准规范,并应在CNAS公布的范围内)
6.校准物品的描述、状态和明确的标识(一般为设备的制造商,型号,序列号,设备的内部唯一识别号等信息)。
7.对结果的有效性和应用至关重要的校准物品的接收日期和进行校准的日期
8.如与结果的有效性和应用相关时,实验室或其他机构所用的抽样计划和程序的说明
9.校准的结果,适用时,带有测量单位。
10.校准证书批准人的姓名、职务、签字或等效的标识(即报告上的授权签字人信息,要与CNAS公布的一致)
11.相关时,结果仅与被校准物品有关的声明。
12.校准活动中对测量结果有影响的环境条件
13.测量不确定度和/或符合确定的计量规范或条款的声明。
14.测量可溯源的依据(溯源的标准器和溯源到国家基准的声明)
15.实验室被授权的有效的证明(CNAS的Logo,及校准字样和实验室编号)
参与人数 1威望 +1 收起 理由
上帝 + 1 热心回复
美华 发表于 2009-7-1 09:14:08 | 显示全部楼层
我公司是UL的合作伙伴,在华南和华东均有合作的国家校准实验室,均提供符合UL要求的校准证书。若需要协助,请联系!
xuwenl 发表于 2009-7-3 18:45:47 | 显示全部楼层
谢谢美华的翻译,受益匪浅。只是看楼主的帖子,14.翻译成“14.测量可溯源的依据(溯源至国家基准的声明)”似乎更符合。
GMT+8, 2026-4-10 03:01
