[螺纹/齿轮] 谁有关于WKG、BSW系列螺纹塞规的资料?
机器猫 发表于 2009-8-3 08:04:05 | 显示全部楼层 |阅读模式
谁有关于WKG、BSW系列螺纹塞规的资料?请发一个,谢了!
august 发表于 2009-8-3 16:56:07 | 显示全部楼层
牙型角  55°
曙光 发表于 2009-8-5 09:18:40 | 显示全部楼层
b.s.w惠氏粗牙螺纹55°无锥度澳大利亚英国马来西亚标准
快乐星球 发表于 2011-7-20 14:32:08 | 显示全部楼层
我也需要BSW螺纹规的标准。
浮生若梦 发表于 2011-7-21 22:10:56 | 显示全部楼层
英制普通螺纹 -- 粗牙 -- BSW
英制普通螺纹 (惠氏螺纹) -- 粗牙 (BSW)
名义尺寸
Ww        牙型代号        大径
mm
d=D        螺距
mm
p        每英寸牙数
tpi        中径
mm
d2=D2        小径
外螺纹
d3        牙型高
H1        底孔直径
mm
1/16"        BSW        1.587        0.423        60        1.315        1.050        0.270        1.15
3/32"        BSW        2.381        0.529        48        2.041        1.703        0.338        1.90
1/8"        BSW        3.175        0.635        40        2.768        2.362        0.406        2.50
5/32"        BSW        3.969        0.793        32        3.459        2.952        0.507        3.20
3/16"        BSW        4.762        1.058        24        4.084        3.407        0.677        3.70
7/32"        BSW        5.556        1.058        24        4.878        4.201        0.677        4.50
1/4"        BSW        6.350        1.270        20        5.537        4.724        0.813        5.10
5/16"        BSW        7.938        1.411        18        7.034        6.131        0.904        6.50
3/8"        BSW        9.525        1.588        16        8.509        7.492        1.017        7.90
7/16"        BSW        11.113        1.814        14        9.951        8.789        1.162        9.20
1/2"        BSW        12.700        2.117        12        11.345        9.990        1.355        10.40
5/8"        BSW        15.876        2.309        11        14.397        12.918        1.479        13.40
3/4"        BSW        19.051        2.540        10        17.424        15.798        1.627        16.25
7/8"        BSW        22.226        2.822        9        20.419        18.611        1.807        19.25
1"        BSW        25.400        3.175        8        23.368        21.335        2.033        22.00
1 1/8"        BSW        28.576        3.629        7        26.253        23.929        2.324        24.50
1 1/4"        BSW        31.751        3.629        7        29.428        27.104        2.324        27.25
1 3/8"        BSW        34.926        4.233        6        32.215        29.505        2.711        30.25
1 1/2"        BSW        38.100        4.233        6        35.391        32.680        2.711        33.50
1 5/8"        BSW        41.277        5.080        5        38.024        34.771        3.253        35.50
1 3/4"        BSW        44.452        5.080        5        41.199        37.946        3.253        38.50
1 7/8"        BSW        47.627        5.645        4 1/2        44.012        40.398        3.614        41.25
2"        BSW        50.802        5.645        4 1/2        47.187        43.573        3.614        44.50
2 1/4"        BSW        57.152        6.350        4        53.086        49.020        4.066        50.00
2 1/2"        BSW        63.502        6.350        4        59.436        55.370        4.066        56.00
2 3/4"        BSW        69.853        7.257        3 1/2        65.205        60.558        4.647        61.50
3"        BSW        76.203        7.257        3 1/2        71.556        66.909        4.647        68.00
3 1/4"        BSW        82.553        7.816        3 1/4        77.548        72.544        5.005        73.75
3 1/2"        BSW        88.903        7.816        3 1/4        83.899        78.894        5.005        80.00
3 3/4"        BSW        95.254        8.467        3        89.832        84.410        5.422        85.50
4"        BSW        101.604        8.467        3        96.182        90.760        5.422        92.00
4 1/4"        BSW        107.954        8.835        2 7/8        102.297        96.639        5.657        98.00
4 1/2"        BSW        114.304        8.835        2 7/8        108.647        102.990        5.657        104.20
4 3/4"        BSW        120.665        9.237        2 3/4        114.740        108.625        5.915        110.00
5"        BSW        127.005        9.237        2 3/4        121.090        115.176        5.915        116.50
5 1/4"        BSW        133.355        9.677        2 5/8        127.159        120.963        6.196        122.50
5 1/2"        BSW        139.705        9.677        2 5/8        133.509        127.313        6.196        128.50
5 3/4"        BSW        146.055        10.160        2 1/2        139.549        133.043        6.506        134.50
6"        BSW        152.406        10.160        2 1/2        145.900        139.394        6.506        141.00
英制普通螺纹 -- 细牙 -- BSF
英制普通螺纹 (惠氏螺纹) -- 细牙 (BSW)
名义尺寸
BSF        牙型代号        大径
mm
d=D        螺距
mm
p        每英寸牙数
tpi        中径
mm
d2=D2        小径
外螺纹
d3        牙型高
H1        底孔直径
mm
3/16        BSF        4.763        0.794        32        4.255        3.747        0.508        4.00
7/32        BSF        5.556        0.907        28        4.975        4.394        0.581        4.60
1/4        BSF        6.350        0.977        26        5.725        5.100        0.625        5.30
9/32        BSF        7.142        0.977        26        6.518        5.893        0.625        6.10
5/16        BSF        7.938        1.156        22        7.199        6.459        0.739        6.80
3/8        BSF        9.525        1.27        20        8.712        7.899        0.813        8.30
7/16        BSF        11.113        1.411        18        10.209        9.304        0.904        9.70
1/2        BSF        12.700        1.588        16        11.684        10.668        1.017        11.10
9/16        BSF        14.288        1.588        16        13.272        12.256        1.017        12.70
5/8        BSF        15.875        1.814        14        14.712        13.549        1.162        14.00
11/16        BSF        17.463        1.814        14        16.300        15.137        1.162        15.50
3/4        BSF        19.050        2.117        12        17.693        16.336        1.355        16.75
13/16        BSF        20.638        2.117        12        19.281        17.924        1.355        18.25
7/8        BSF        22.225        2.309        11        20.747        19.269        1.479        19.75
1        BSF        25.400        2.54        10        23.774        22.148        1.627        22.75
1 1/8        BSF        28.575        2.822        9        26.769        24.963        1.807        26.50
1 1/4        BSF        31.750        2.822        9        29.944        28.138        1.807        28.75
1 3/8        BSF        34.925        3.175        8        32.893        30.861        2.033        31.50
1 1/2        BSF        38.100        3.175        8        36.068        34.036        2.033        34.50
1 5/8        BSF        41.275        3.175        8        39.243        37.211        2.033        38.00
1 3/4        BSF        44.450        3.629        7        42.126        39.802        2.324        40.50
2        BSF        50.800        3.629        7        48.476        46.152        2.324        47.00
2 1/4        BSF        57.150        4.234        6        54.440        51.730        2.711        53.00
2 1/2        BSF        63.500        4.234        6        60.790        58.080        2.711        59.00
2 3/4        BSF        69.850        4.234        6        67.140        64.430        2.711        -
3        BSF        76.200        5.08        5        72.946        69.692        3.253        -
3 1/4        BSF        82.550        5.08        5        79.296        76.042        3.253        -
3 1/2        BSF        88.900        5.645        4 1/2        85.285        81.670        3.614        -
3 3/4        BSF        95.250        5.645        4 1/2        91.635        88.020        3.614        -
4        BSF        101.600        5.645        4 1/2        97.985        94.370        3.614        -
4 1/4        BSF        107.950        6.35        4        103.886        99.822        4.066        -
GMT+8, 2026-4-7 02:03
