接触电阻对ESD仪器车电性能测试的影响
飘八零 发表于 2009-8-30 18:06:39 | 显示全部楼层 |阅读模式
季启政 魏强
北京东方计量测试研究所,北京100086
摘 要:对防静电系统中的接触电阻进行了分析,给出了接触电阻的理论模型,提出了减小接触电阻的具体措施。这些措施提高了防静电系统测试的准确度,对现场防静电设备ESD性能的测量具有重要的现实意义。[著者文摘]
Effect of the Contact Resistance on Electrostatic Property Test of the ESD Apparatus VehicleJI Qi-zheng ,WEI Qiang Beijing Orient Institute of Measurement & Test Chinese Academy of Space Technology, Beijing 100086Abstract:The contact resistance of antistatic system is analyzed, and the theoretical model of con- tact resistance is presented, finally the measures of reducing contact resistance are proposed in detail. The measurement accuracy of antistatic system can been improved, and it is very significant for the ESD property test of antistatic epuipments.[著者文摘]
Key words:ESD apparatus vehicle Contact resistance Antistatic technique
接触电阻对ESD仪器车电性能测试的影响.rar
247.95 KB, 下载次数: 38, 下载积分: 金币 -1
参与人数 1金币 +5 收起 理由
maintek + 5 加分鼓励
GMT+8, 2026-4-6 01:47
