ASTM A 1004-1999确定用于冷成形的框架构件的金属被涂覆...
兑水 发表于 2009-9-10 19:58:02 | 显示全部楼层 |阅读模式
A1004/A1004M-99 Standard Practice for Establishing Conformance to the Minimum Expected Corrosion Characteristics of Metallic, Painted-Metallic, and Nonmetallic-Coated Steel Sheet Intended for Use as Cold Formed Framing Members
ASTM A 1004-1999.pdf
25.47 KB, 下载次数: 1, 下载积分: 金币 -1
GMT+8, 2026-4-10 10:14
