ASTM C 954-2004 将厚度为0.033至0.112英寸(0.84至2.84mm)...
兑水 发表于 2009-9-20 07:23:32 | 显示全部楼层 |阅读模式
C954-00 Standard Specification for Steel Drill Screws for the Application of Gypsum Panel Products or Metal Plaster Bases to Steel Studs From 0.033 in. (0.84 mm) to 0.112 in. (2.84 mm) in Thickness
ASTM C 954-2004.pdf
16.36 KB, 下载次数: 1, 下载积分: 金币 -1
GMT+8, 2026-4-10 05:12
