[辐射剂量] 射线测量的单位
三妹乖乖 发表于 2009-12-3 11:27:58 | 显示全部楼层 |阅读模式
射线测量的单位
The curie is the number of particles per second from 1 gram of Radium = 3.7 x 10 E10 counts/second = 37 billion cps. = 37 billion Becquerel.
1 Becquerel (Bq) = 1 count per second = 1 event per second
1 microcurie = 1 uCi = 37,000 Bq = 37,000 cps.
1 microcurie = 2.22 x 10E6 disintegrations / minute = 2,220,000 cpm.
1 nanocurie = 1 billionth of a curie = 2,220 disintegrations / minute.
1 picocurie = 2.2 disintegrations / min.
Dosage units:
Gray (Gy) = 1 Joule/kg
Sievert (Sv) = Gray x QF, where QF is a "quality factor" based on the type of particle.
QF for electrons, positrons, and xrays = 1 QF = 3 to 10 for neutrons, protons dependent upon the energy transferred by these heavier particles.
QF = 20 for alpha particles and fission fragments.
The Sievert is a measure of biological effect.
Converting older units:
1 rad = 1 centigray = 10 milligrays ( 1 rad = 1cGy = 10 mGy )
1 rem = 1 centisievert = 10 millisieverts ( 1 rem = 1cSv = 10 mSv )
1 mrad = 10 uGy
Nominal background radiation absorbed dose of 100 mrad/year = 1 mGy/yr.
Nominal background radiation dose biological equivalent of 100mrem/year = 1mSv/yr.
Occupational whole body limit is 5 rem/yr = 50 mSv/yr. ( Recently proposed that levels be reduced to 2 rem/yr.)
2.5 mrem/hr or 25 uSv/hr is maximum average working level in industry.
Exposure rate from Naturally Occurring Radioactive Material (NORM) ; an empirically derived conversion factor for Ra-226 decay series: 1.82 microR/ hour = 1 picoCurie/gram.
lishengchun 发表于 2011-4-3 22:10:47 | 显示全部楼层
量的名称      非法定计量单位        法定计量单位             换算关系
照射量          伦琴(R)                      C/kg(库/千克)         1R=2.58*10E-4C/kg
剂量当量        拉德(rad)                   Gy(戈瑞)              1rad=10E-2Gy
吸收剂量        雷姆(rem)            Sv(希沃)                1rem=10E-2Sv
放射性活度      居里(Ci)                     Bq(贝克勒尔)          1Ci=3.7*10E-10Bq
zhansir 发表于 2014-11-9 03:33:56 | 显示全部楼层
不错,我补充点中文的吧!
常用辐射量与单位.pdf
206.55 KB, 下载次数: 18, 下载积分: 金币 -1
hbjl0392 发表于 2015-7-17 10:02:18 | 显示全部楼层
有一定的参考价值
GMT+8, 2026-4-6 02:56
