[湿度] 无线温湿度测量传感器网络设计
上帝 发表于 2007-10-27 21:12:21 | 显示全部楼层 |阅读模式
姚传安
河南农业大学机电工程学院,河南郑州450002
摘 要:无线传感器网络是当前信息领域中研究的热点之一,可用于特殊环境实现信号的采集、处理和发送;文中介绍了一种无线温湿度传感器网络的设计,以PIC单片机为核心,利用集成湿度传感器和数字温度传感器设计出了温湿度传感器网络节点的硬件电路,并通过无线收发模块与控制中心通信,讨论和提出了传感器节点的低功耗设计以及数据通信的可靠性方法;该系统稳定性好,通信效率高,可广泛应用于环境检测。[著者文摘]
关键词:无线传感器 温湿度测量 可靠性 低功耗
Design of Wireless Sensor Network for Monitoring Temperature and HumidityYao Chuanan Mechanical and Electrical Engineering College, Henan Agricultural University, Zhengzhou 450002, ChinaAbstract:Wireless sensors network is a new research field. It can be used in some special situation for signal collection, processing and transmitting. Design of a kind of wireless sensor network for monitoring temperature and humidity is presented. Using relative humidity sensor and digital temperature sensor on the basis of PIC MCU, we design a kind of temperature and humidity sensor unit, which linked into control center by wireless transceiver. Low- power design and reliable communication of sensor nods are introduced in detail. This is'a stable and efficient system which can be widely used in environment monitoring.[著者文摘]
Key words:wireless sensor temperature and humidity measurement reliable communication low-power
无线温湿度测量传感器网络设计.pdf
187.63 KB, 下载次数: 6, 下载积分: 金币 -1
GMT+8, 2026-4-7 03:14
