[概念] 空话连篇-评UA评定(5)
史锦顺 发表于 2012-8-29 07:25:15 | 显示全部楼层 |阅读模式
                     空话连篇-UA评定(5)
        史锦顺
不确定度论的B类评定,本质上不是评定,只是收集信息。GUMVIM这两大文件的B类评定各不相同,我国的规范,《JJF1059-1999》从GUM,《JJF1001-2011》从VIM;由于原本都是空话,抄哪个,也还是空话。从大量的样板评定的内容看,执行的又是另一套,不搞实质性的测量,只在别人的数据上兜圈子,大都是重复或走形式。本段先论UA评定“说空话”的本质,下段再议UA评定“走形式”的表现。
(一)B类评定版本
1 GUM
4.3 Type B evaluation of standard uncertainty
标准不确定度的B类评定
4.3.1 For an estimate xi of an input quantity Xi that has not been obtained from repeated observations, the associated estimated variance u^2(xi) or the standard uncertainty u(xi) is evaluated by scientific judgement based on all of the available information on the possible variability of Xi . The pool of information may include
(1) previous measurement data;
(2)experience with or general knowledge of the behaviour and properties of relevant materials and instruments;
(3)manufacturer's specifications;
(4) data provided in calibration and other certificates;
(5)uncertainties assigned to reference data taken from handbooks.
For convenience, u2(xi) and u(xi) evaluated in this way are sometimes called a Type B variance and a Type B standard uncertainty, respectively.
      当输入的Xi的的估计值xi不由观测得到时,估计方差u^2(xi)或标准不确定度u(xi)可用Xi的可能变化的全部有关信息的判断来评定。收集的信息可包括:
   (1)以前测量的数据;
   (2)经验和有关材料和仪器特性的一般知识;
   (3)制造厂的技术说明书;
   (4)校准和其他证书提供的数据
   (5)取自手册的参考数据给出的不确定度。
   为了方便起见,用这种方法估计的u^2(xi)u(xi)的值通常分别B类方差和B类标准不确定度。(此段由叶德培翻译,史锦顺仅将原文sometimes由“有时”改译为“通常”。
  (接下页)
 楼主| 史锦顺 发表于 2012-8-29 07:32:32 | 显示全部楼层
1# 史锦顺  文
2 VIM
2.29 Type B evaluation of measurement uncertainty
Type B evaluation
测量不确定度的B类评定
    B类评定
evaluation of a component of measurement uncertainty determined by means other than a Type A evaluation of measurement uncertainty
    用不同于A类测量不确定度评定的方法对测量不确定度分量的评定。
EXAMPLES Evaluation based on information
评定所据信息的例
(1) associated with authoritative published quantity values,
权威机构发布的量值;
(2) associated with the quantity value of a certified reference material,
有证标准物质的量值;
(3) obtained from a calibration certificate,
校准证书;
(4) about drift,
漂移;
(5) obtained from the accuracy class of a verified measuring instrument,
经检定的测量仪器的等级;
(6) obtained from limits deduced through personal experience.
根据人员经检推断的极限值等。
(史注:本段译文引自《JJF1001-2011》)
(二)空话剖析
  GUM (1)以前测量的数据
  【史评】测量、计量,都要进行现时的测量,并依据测量结果作出独立的判断。以前测量的数据,还能用来计算吗?又该以多大的权重加入今天的测量结果?这是一条没用的空话。
GUM (2)经验和有关材料和仪器特性的一般知识
【史评】一般的知识不能代替对特定量值、特定仪器的认识。知识该有,只是测量计量中不能用此“一般知识”为依据。
GUM (3)制造厂的技术说明书
【史评】测量计量工作者,一定要看说明书,而且要熟悉仪器说明书。
  对计量工作来说,说明书的指标是对仪器的要求,只有实测性符合指标,才算合格。但要知道,说明书的规定只是个要求,合格与否的依据是实测数据。不动用计量标准,无法判别。
  对测量者来说,依据的是测量仪器,相信的是测量仪器规格。只能相信,而无法评定。因为测量者没有计量标准。
   (接下页)
 楼主| 史锦顺 发表于 2012-8-29 07:37:38 | 显示全部楼层
2# 史锦顺
    GUM (4)校准和其他证书提供的数据
    【史评】验证检定证书、校准证书,是必要的。已经检定或校准,就该相信,不必再评定。
    GUM (5)取自手册的参考数据给出的不确定度
    【史评】手册的参考数据是一般量,代替不了具体对象、具体条件下的实际测量。
    VIM (1)权威机构发布的量值
    【史评】权威机构能发布多少量值?测量计量,量值千万、亿万,通常与此条连不上。
    VIM (2)有证标准物质的量值
    【史评】此标准物质可当标准,代替不了对实际物质的测量。
    VIM (3)校准证书
    【史评】相信即可。不是评定的问题。
    VIM (4)漂移
    【史评】被检测量仪器的漂移是计量工作中该测量的对象,不测不行。测量中,要计及,但无法评定。
    VIM (5)经检定的测量仪器的等级
    【史评】计量中,是检定对象,不测不行;测量中,是依据,要相信,无法评定。
    VIM (6)根据人员经检推断的极限值等
    【史评】仅能避免出不合情理的差错,无法据以评定。
    几句简短的总结
    所谓B类评定,不过是收集些信息;知识与信息只能参考,不能成为依据。测量计量不实际测量是不行的。所谓B类评定,不过是在讲空话。而且是空话连篇,一个文件一个样,没准谱。
jhabcd 发表于 2012-9-2 21:21:15 | 显示全部楼层
啊?这样的话还宣贯不确定度?
林壮壮 发表于 2012-9-3 16:06:16 | 显示全部楼层
不确定度本来就是一个人算一个数据出来的
林壮壮 发表于 2012-9-3 16:07:26 | 显示全部楼层
B类确实不怎么靠谱啊
GMT+8, 2026-4-6 11:28
