[频率] NIM的微波-光学频率基准研究——复现米和秒定义
兑水 发表于 2008-1-20 13:20:11 | 显示全部楼层 |阅读模式
李天初
中国计量科学研究院(NIM),北京100013
摘 要:报道中国计量科学研究院(NIM)在微波一光学频率计量研究的新进展:用NIM4激光冷却-铯原子喷泉钟复现国际单位制(SI)时间单位秒(s),用飞秒(FS)光学频率梳间接复现长度单位米(m)并标定稳频激光波长实际实施米定义。NIM4铯原子喷泉钟的不确定度达到5×10^-15,飞秒(FS)光梳锁定到NIM4钟控制的氢钟后,其频率不确定度为2.2×10^-14。在此基础上讨论铯原子喷泉钟、稳频激光、FS光梳的作用、意义和相互关系。最后简要介绍NIM5铯原子喷泉钟的研究进展和2006年起NIM立题研制锶原子存储光钟。[著者文摘]
关键词:计量 频率基准 稳频激光 铯原子喷泉钟 飞秒光梳
Microwave- Optical Frequency Standards at NIM: Realizing of Definition of Metre and SecondLi Tianchu National Institute of Metrology ( NIM ) , Beijing 100013, ChinaAbstract:The paper presents the realization, at NIM, of SI time unit second using the NIM4 cesium fountain clock, SI length unit meter using a femto-second (FS) optical frequency comb and calibration of wavelengths of stabilized lasers by this FS comb. The uncertainty of NIM4 fountain clock was evaluated as 5 × 10^15. The frequency uncertainty of the FS optical comb locked to a H-maser, which is steered by NIM4 clock, was estimated as 2.2 × 10^- 14 The function, significance of Cs fountain clock, stabilized lasers, optical comb and relationship among them are discussed. Finally the progress of NIM5 fountain clock and the construction of a Sr atom optical clock started in 2006 at NIM are reported.[著者文摘]
Key words:metrolo; frequency standard; stabilized laser; Cs fountain clock; FS optical comb
NIM的微波-光学频率基准研究——复现米和秒定义.pdf
259.45 KB, 阅读权限: 10, 下载次数: 9, 下载积分: 金币 -1
GMT+8, 2026-4-5 15:06
