[脉冲参数] 脉冲信号源脉宽参数的测量不确定度分析
csxfjsw123 发表于 2008-1-25 15:58:52 | 显示全部楼层 |阅读模式
脉冲信号源脉宽参数的测量不确定度分析
赵自文中国空空导弹研究院,河南洛阳471009摘 要:对脉冲信号源脉宽指标进行了不确定度的分析和评定。分析了脉冲信号源脉宽测量时的主要误差来源,包括计数器测量重复性、触发定时误差、时基误差、放大器滞后误差、分辨力误差等;结合这些影响因素,评估了脉宽测量的合成标准不确定度和扩展不确定度。[著者文摘]
关键词:脉冲信号源 脉冲宽度 不确定度分析
分类号: TM930.115 TM935.41[著者标引]文献标识码:A文章编号:1002-6061(2006)04-0039-03栏目信息:误差分析
相关文献:主题相关 全文快照
Measurement Uncertainty of Pulse Width of Pulse GeneratorZHAO Zi-wen China Airborne Missile Academy, Luoyang 471009, ChinaAbstract:In this paper, the uncertainty of evaluation results of pulse width of pulse generator is described. The main error sources of pulse width measurement, including counter's repeatability, trigger level timing error, time base error, the amplifier hysteresis error, LSD displayed error, etc. are analyzed. According to these effect factors, the combined standard uncertainty and expanded uncertainty of pulse width measurement are evaluated.[著者文摘]
Key words:pulse generator; pulse width; uncertainty analysis
脉冲信号源脉宽参数的测量不确定度分析.pdf
149.12 KB, 下载次数: 57, 下载积分: 金币 -1
GMT+8, 2026-4-6 01:47
