[其它] 硫代硫酸钠标准溶液标定的不确定度评定
csxfjsw123 发表于 2008-1-25 16:21:35 | 显示全部楼层 |阅读模式
硫代硫酸钠标准溶液标定的不确定度评定
余奇飞漳州职业技术学院食品与生物工程系,福建漳州363000摘 要:对硫代硫酸钠标准溶液标定的不确定度分析,对其标定结果的质量进行了定量表征。结果表明,硫代硫酸钠标准溶液的浓度为0.1017±0.00035mol/L(k=2),测量结果重复性的不确定度对总体不确定度作用最大。[著者文摘]
关键词:不确定度 浓度评定 硫代硫酸钠
分类号: O652[著者标引]文献标识码:A文章编号:1673-4823(2006)03-0125-04栏目信息:化学与环保
相关文献:主题相关 全文快照
Evaluation of uncertainty for determination of sodium thio-sulfate standard solutionYU Qi-fei Food and Bioengineering Department, Zhangzhou Institute of Technology, Zhangzhou, Fujian, 363000, ChinaAbstract:The quality of result of measurement is characterized quantitatively through the analysis of the uncertainty for determination of sodium thio-sulfate standard solution. The result shows the concentration of sodium thio-sulfate standard solution is 0.1017±0.00035mol/L(k=2), and the uncertainty of repeatability of results of measurements contributes mostly to total comparing with others.[著者文摘]
Key words:uncertainty; evaluation; sodium thio-sulfate
硫代硫酸钠标准溶液标定的不确定度评定.pdf
173.94 KB, 下载次数: 32, 下载积分: 金币 -1
GMT+8, 2026-4-6 15:27
