[电压] 灵敏度要求 - 高压机的灵敏度每年至少需要核查一次
chenboyou 发表于 2013-8-2 09:04:01 | 显示全部楼层 |阅读模式
1. 高压机校准 - UL 要求摘录如下(灵敏度要求 - 高压机的灵敏度每年至少需要核查一次)
Sensitivity Requirements - At least once each year the sensitivity of the dielectric equipment is to be checked. The sensitivity of the equipment is to be such that when adjusted to produce the required test voltage and with a 120,000 ohm resistor across the test terminals, the equipment indicates a "breakdown" (a nonconforming performance indication by the tester) within 0.5 seconds. The resistor used shall be provided by the manufacturer and shall have a resistance found to be equal to or greater than 120,000 ohm when measured using a calibrated ohmmeter traceable to the National Institute of Standards and Technology (NIST). If the equipment does not meet this sensitivity test, it shall be readjusted and provision made to maintain the proper calibration.
目前,《JJG 795-2004 耐电压测试仪检定规程》 此项目是不作检测范围,我司产品大部分销往美国市场,必须要做Sensitivity Requirements,建议近快修改此检定规程。
礼匪 发表于 2013-8-2 12:42:11 | 显示全部楼层
笑话,这种也叫检测条件?
耐压仪规范远比UL详细有效
 楼主| chenboyou 发表于 2013-8-5 09:15:23 | 显示全部楼层
请电磁学计量权威人士关注我提出问题,要求尽快修该《JJG 795-2004 耐电压测试仪检定规程》。
 楼主| chenboyou 发表于 2013-8-5 09:25:40 | 显示全部楼层
回复 2# 礼匪
    什么是笑话?是UL在我司审核时多次要求“耐压测试仪应增加Sensitivity Requirements检定的项目”,请你不这样口谓讲话!唉!!!
 楼主| chenboyou 发表于 2013-8-5 09:30:52 | 显示全部楼层
再说明一下:Sensitivity Requirements - At least once each year the sensitivity of the dielectric equipment is to be checked. The sensitivity of the equipment is to be such that when adjusted to produce the required test voltage and with a 120,000 ohm resistor across the test terminals, the equipment indicates a "breakdown" (a nonconforming performance indication by the tester) within 0.5 seconds. The resistor used shall be provided by the manufacturer and shall have a resistance found to be equal to or greater than 120,000 ohm when measured using a calibrated ohmmeter traceable to the National Institute of Standards and Technology (NIST). If the equipment does not meet this sensitivity test, it shall be readjusted and provision made to maintain the proper calibration.
灵敏度的要求-至少每年一次的介电设备的灵敏度进行检查。该设备的灵敏度是这样的,当调整以产生所要求的试验电压和一个120000欧姆的电阻在测试终端设备,表示“崩溃”(一个不合格的绩效指标的测试)在0.5秒。电阻器必须由制造商提供的,必须有一个电阻的发现是等于或大于120000欧姆欧姆表测量时,使用校准可溯源到国家标准与技术研究所(NIST)。如果设备不符合这种敏感性试验,应当调整,保持适当的校准设置。
angus_tan 发表于 2013-8-5 09:35:41 | 显示全部楼层
回复 5# chenboyou
    按要求做一个点检装置, 一端PASS 一端FAIL, 具体要求按照UL的标准(
)来,其实很简单的,点检装置做出来后经过校准.就符合要求了,谢谢!
礼匪 发表于 2013-8-5 10:22:20 | 显示全部楼层
高压机对不同产品规格需要的工作电压不同,设定的漏电流阀值也不同,如果按楼主UL的要求,不知如何操作??楼主说的不过是个点检器的要求,和规程的要求差远了。
 楼主| chenboyou 发表于 2013-8-5 15:23:54 | 显示全部楼层
回复 7# 礼匪
    第一步:在耐电压测试仪输出端接上120,000 ohm,泄露电流5mA(或其它档位),调节其输出电压直至切断电压并报警。
第二步:在耐电压测试仪输出端连接好示波器探头(倍压探头>1Kv,并调节相应参数)。
第三步:测量其时间,按耐电压测试仪启动按键,输出电压后切断报警即可。如果是AC电压输出时(如:正弦波)就能抓到其波形并保存下来(一般地示波器可能没有此功能,如:TDS3012B可用),再读取其波形时间(UL要求其电压输出时间小于0.5S)。
可能还是没有表达清楚,见谅!《JJG 795-2004 耐电压测试仪检定规程》是不作测试要求,美国新版UL是作强制要求,因此,建议《JJG 795-2004 耐电压测试仪检定规程》也应该尽快修改,CNAS报告得不到UL认同。
礼匪 发表于 2013-8-6 13:49:03 | 显示全部楼层
输出电压后切断报警即可?
此句如何理解?
 楼主| chenboyou 发表于 2013-8-7 08:50:02 | 显示全部楼层
输出电压后切断报警解释:如设定2mA、1Kv、外接0.5Mohm,按耐电压测试仪启动按键,输出电压后切断并报警,就是这一时间要小于0.5秒。
礼匪 发表于 2013-8-7 14:53:07 | 显示全部楼层
输出电压后切断报警解释:如设定2mA、1Kv、外接0.5Mohm,按耐电压测试仪启动按键,输出电压后切断并报警,就 ...
   这个JJG的确没有测这个项目的
西鼠 发表于 2013-8-7 17:10:47 | 显示全部楼层
就是说电压上升到设定值1kV的时间要小于0.5秒
BOMCO刘浩 发表于 2013-8-15 22:05:01 | 显示全部楼层
如果认为规程有问题。是需要往哪提呢?规程作为法律法规。应向地方人民代表大会提吗?
 楼主| chenboyou 发表于 2013-8-19 08:00:09 | 显示全部楼层
本版面权威人士,也是很不错沟通路经。
 楼主| chenboyou 发表于 2013-8-19 08:00:41 | 显示全部楼层
本版面权威人士,也是很不错沟通路经。
礼匪 发表于 2013-8-22 09:51:39 | 显示全部楼层
如果认为规程有问题。是需要往哪提呢?规程作为法律法规。应向地方人民代表大会提吗? ...
   并不一定要修改,各国有各国的标准。
俊伟 发表于 2014-2-12 09:58:51 | 显示全部楼层
我现在也碰到测灵敏度的问题,有点不太懂了,用什么型号的示波器探头阻抗120K欧跪求急!!
海牛神 发表于 2014-2-12 13:53:09 | 显示全部楼层
我觉得耐压机的输出容量很重要,在负载阻值很很低的情况下,加在负载的电压要低于耐压机的输出示值。
 楼主| chenboyou 发表于 2014-2-13 09:23:06 | 显示全部楼层
我觉得耐压机的输出容量很重要,在负载阻值很很低的情况下,加在负载的电压要低于耐压机的输出示值。 ...
是的,一般是500VA.
 楼主| chenboyou 发表于 2014-2-13 09:25:09 | 显示全部楼层
我现在也碰到测灵敏度的问题,有点不太懂了,用什么型号的示波器探头阻抗120K欧跪求急!! ...
给邮箱,我提文件给你参考。
GMT+8, 2026-4-6 12:30
