铷原子钟
nhbbobb 发表于 2008-1-26 15:57:42 | 显示全部楼层 |阅读模式
Symmetricom Efratom LPRO-101 铷振荡器/铷原子钟 10M GPS驯服钟
http://nhbbobb.ik8.com/GPS/b_lrg.jpg
Key Features
10 MHz Sine Wave
1.5 Inch Total Height
<5e-11/month Aging
Single 24 Vdc Supply; Wide Operating Supply Range (19 to 32V)
Alarm Signal for Rb Unlock
Meets TDMA and GSM Frequency Requirements Without an External Reference or Routine Calibration
CE Compliant
symmetricom Efratom FRS 铷振荡器/铷钟 10M GPS驯服钟
http://pic.seekpai.com/1/137469_113812fa4dc.jpg
Aging:
Monthly (after 1 month) <5E-11/month
10 Years <1E-9
Frequency Accuracy ±5E-11 (25ºC)
(at shipment)
Frequency Retrace: <±2.5E-11
(after 24 hours power on @ 25ºC and up to 48 hours power off)
Short Term Stability: τ = 1 sec <2.5E-11
τ = 10 sec <0.8E-11
τ = 100 sec <0.25E=11
Frequency Control:
Internal trim range (trimpot) ±1.5E-9
External trim range (electronic) ±1.5E-9 (0 V to +5 V)
Warm-up: at -20ºC at 25ºC
Time to Lock <8.7 min <5.4 min
Time to <1E-9 <10.2 min <7.3 min
Time to <4E-10 <12.7 min <10.6 min
Max Input (Amps) @ 24 V <1.45 A <1.43 A
Input Voltage Range: +19 to +32 Vdc
Voltage Sensitivity: .72E-11/V (over the input voltage range)
Input Power, Quiescent: +24 Vdc <13 W @ 25ºC
+19 Vdc <7 W @ 65ºC
Status Monitor:
Analog VCXO lamps, lamp volts
(20K impedance, filtered)
Digital LOCK monitor: 5 V CMOS load
Lock <0.2 V (CMOS low)
Unlock >2.5 V (CMOS high)
Efratom slcr-101 铷原子钟 10mhz 改进版 瘦身版
http://www.amoj.cn/pic/UploadFile/08012222AE1.jpg
Key Features
10 MHz Sine Wave
<5e-11/month Aging
CE Compliant
FEI FE 5650A 铷频标 铷原子钟 超高精度 1pps
http://www.amoj.cn/pic/UploadFile/08012513C95.jpg
应用领域: 电信、移动通信、测试设备、计量标准
特点: 高稳定度,尺寸体积小
   FE-5650A 铷原子振荡器是美国FEI公司生产的高性能铷原子振荡器产品,具有稳定度高,体积小,重量轻等特点。
1. 输出:10MHz
2. 老化率:2E-11/日
3. 复现性:5E-11
4. 短期稳定度:
   1s :<1.4E-11   10s: < 4.4E-12   100s: < 1.4E-12
5. 相位噪声
   -125dBc/Hz @100Hz   -145dBc/Hz @1kHz
6. 尺寸
   37×77×76mm
FEI FE 5680A 铷频标 铷原子钟 10mhz 频率源
http://www.amoj.cn/pic/UploadFile/08012223190.jpg
频率 10MHZ(工厂可设置为1HZ到20MHZ)
输出 0.5Vrms50Ω正弦波
可调节 1×10(-11)--10的负11次方
重现性 5×10(-11)
FEI FE 5682A 铷频标 铷原子钟 10mhz 频率源
输出 0.5Vrms50Ω正弦波
重现性 5×10(-11)
http://www.amoj.cn/pic/UploadFile/08012412458.jpg
瑞士TEMEX LPFRS 铷原子钟 铷频标 10mhz
http://www.amoj.cn/pic/UploadFile/0801251412D.jpg
特点: 经济型,低漂移
   LPFRS 铷原子振荡器是瑞士TEMEX公司生产的高性能铷原子振荡器产品,具有准确度高,价格低等特点,与FE5650兼容。
1. 输出:10MHz
2. 老化率:3E-11/月
3. 复现性:5E-11
4. 短期稳定度:
   1s :<3E-11   10s: < 1E-11   100s: < 3E-12
5. 相位噪声
   -115dBc/Hz @100Hz   -135dBc/Hz @1kHz
6. 尺寸
   76×77×36.5mm
SRS PRS10 10mhz rubidium frequency 铷振荡器 原子钟
http://www.amoj.cn/pic/UploadFile/07120813B15.jpg
输出频率
10MHz ,正弦波
输出幅度
正弦波, 7dBm into 50Ω
频率准确度: 5E-11
长期 ( 老化率 )
月老化率: <5E-11
年老化率: <5E-10
短期 (Allan 方差 )
<2E-11 @ 1 sec
<1E-11 @ 10 sec
<2E-12 @ 100sec
相位噪声
<- 130 dBc/Hz @ 10Hz
<- 140 dBc/Hz @ 100Hz
<- 150 dBc/Hz @ 1 KHz
<- 150 dBc/Hz @ 10 KHz
13580417781 www.amoj.cn
http://shop33457021.taobao.com
GMT+8, 2026-4-6 05:09
