[水质/元素] 水中总硬度测量不确定度的评定
csxfjsw123 发表于 2008-1-30 09:00:48 | 显示全部楼层 |阅读模式
水中总硬度测量不确定度的评定
梁景波[1] 袁东晖[1] 黄锦燕[2] 王宝书[1][1]淄博市环境监测站,山东淄博255040 [2]淄博市产品质量监督检验所,山东淄博255040摘 要:采用EDTA滴定法测定水质总硬度的测量不确定度评定.充分考虑测量重复性、标准溶液的配制、滴定等过程对测量的影响,计算水中总硬度的测量相对合成标准不确定度为1.81×10^-3.[著者文摘]
关键词:总硬度 测量不确定度 评定
分类号: X832[免标]文献标识码:A文章编号:1002-6002(2006)03-0035-04栏目信息:分析测试
相关文献:主题相关
Uncertain Evaluation of Degree of the Measurement of Total Hardness of WaterLIANG Jing-bo , et al 1 .Zibo Environmental Monitoring Station, Zibo 255040, ChinaAbstract:Uncertain degree is evaluated to adopt EDTA titrimetric law to measure total hardness of water quality. Fully consider measuring such impacts on measurement of the course as the disposition and titration of repetitiveness, standard solution, etc., calculate water total measurement of hardness relative to formates standard confirm degree as 1.81 × 10^-3 .[著者文摘]
Key words:Total hardness; The uncertain degree of measurement; Evaluate
水中总硬度测量不确定度的评定.pdf
199.13 KB, 下载次数: 34, 下载积分: 金币 -1
GMT+8, 2026-4-6 17:28
