[质量] 电子天平测量结果不确定度的研究
csxfjsw123 发表于 2008-1-30 09:18:37 | 显示全部楼层 |阅读模式
电子天平测量结果不确定度的研究
萧铜 杨惠敏 刘强天津市计量监督检测科学研究院,天津300192
摘 要:为解决电子天平在测量过程中达到用测量不确定度来统一评价测量结果质量的问题,对电子天平测量结果不确定度进行了研究。依照电子天平复现质量之差的原理,采用分析误差源的方法,研究测量过程中用电子天平来复现质量,给测量结果引入不确定的范围。通过本方法的研究而得到电子天平测量结果不确定度,对电子天平测量结果的质量有了比较可靠的保证。[著者文摘]
关键词:测量 测量结果不确定度 置信因子 置信概率 扩展不确定度
分类号: TH715.116[著者标引]文献标识码:A文章编号:1672-4984(2007)05-0082-03栏目信息:计量技术与工程测试
相关文献:主题相关 全文快照
Research on measurement remit uncertainty of electronic balanceXIAO Tong, YANG Hui-min, LIU Qiang Tianjin Institute of Metrological Supervision and Testing,Tianjin 300192,ChinaAbstract:The problem of evaluating the quality of measurement result was solved by research on uncertainty of measurement of electronic balance. In accordance with the principle of reproducibility of quality errors of electronic balance, the source of errors was analyzed, reproduce quality in the course of measurement which introduced the result into an uncertain field was researched. The uncertainty gained through the research of this method ensures the quality of the result of a measurement of electronic balance.[著者文摘]
Key words:Measurement; Uncertainty of result of a measurement; Confidence factor, Confidence level; Expanded uncertainty
[ 本帖最后由 zcyjkl 于 2008-2-23 06:37 编辑 ]
电子天平测量结果不确定度的研究.pdf
147.65 KB, 阅读权限: 10, 下载次数: 41, 下载积分: 金币 -1
售价: 1 金币  [记录]
参与人数 1金币 +4 收起 理由
zcyjkl + 4 转载技术文章
GMT+8, 2026-4-10 08:29
