[力值] 静重式力标准机砝码交换力平衡控制技术
csxfjsw123 发表于 2008-1-30 14:56:29 | 显示全部楼层 |阅读模式
静重式力标准机砝码交换力平衡控制技术
唐纯谦[1] 张学成[2] 于立娟[2] 周长明[2][1]中国测试技术研究院,四川成都610021 [2]吉林大学,吉林长春130025
摘 要:静重式力标准机利用少量的砝码,进行相等力值间隔逐级加、卸荷时,需要交换砝码。当砝码进行交换时出现逆负荷现象,会对被检测力仪的示值产生影响。阐述了静重式力标准机采用的交换砝码方法是建立在利用弹性力替代砝码重力,砝码交换过程中重力与弹性力达到平衡的基本原理。提出了实现静重式力标准机砝码交换时系统达到力平衡的一种预加荷装置,经砝码交换力平衡控制的力学分析与实验验证,静重式力标准机采用预加负荷实施倒码力平衡控制的方法在理论上和技术上是可行的、有效的。[著者文摘]
关键词:静重式力标准机 砝码交换 逆负荷现象 力平衡控制 预加荷装置
分类号: TB931[免标]文献标识码:A文章编号:1672-4984(2006)06-0020-03栏目信息:计量技术与工程测试
相关文献:主题相关 全文快照
Control technology of force balance in exchanging weights on deadweight force standard machineTANG Chun-qian, ZHANG Xue-cheng, YU Li-juan, ZHOU Chang-ming 1. National Institute of Measurement and Testing Technology, Chengdu 610021, China; 2. Jilin University, Changchun 130025, ChinaAbstract:Weights exchanges are common used in deadweight force standard machine when weight of equal value interval are uploaded and/or downloaded step by step. But the counter-force phenomenon could occur and the indication of testing dynamometer would be influenced.The paper presented the exchanging weights principle based on counterpoising the elastic force and the gravity of weights and introduced a preloading device used as force balancing in exchanging weights.This method that force balance control through preloading is feasible and effective theoretically and technically and has been analyzed in mechanics and proved by experiment.[著者文摘]
Key words:Deadweight force standard machine;Weight change;Counter-force phenomenon;Force balance control;Preloading device
[ 本帖最后由 zcyjkl 于 2008-2-23 06:49 编辑 ]
静重式力标准机砝码交换力平衡控制技术.pdf
212.79 KB, 阅读权限: 10, 下载次数: 30, 下载积分: 金币 -1
售价: 1 金币  [记录]
参与人数 1金币 +4 收起 理由
zcyjkl + 4 转载技术文章
GMT+8, 2026-4-10 08:29
