[技术] MQD-3A Headlight testers
gzwk 发表于 2014-4-21 15:40:26 | 显示全部楼层 |阅读模式
1Environmental Conditions:
      Temperature:     -5°C ~ 40°C
      Relative Humidity: ≤90%
      Power supply:     AC220V ±10%,50±1Hz
2.Measurement Range:
   LuminousIntensity:0 ~ 120000cd
   Optical AxisOffset:
      High Beam: Vertical:   (Up)400mm/10m ~ (Down)560mm/10m
          Horizontal: (Left)560mm/10m ~(Right)560mm/10m
      Low Beam: Vertical:   (Up)400mm/10m ~ (Down)560mm/10m
           Horizontal:(Left)560mm/10m ~(Right)560mm/10m
   Elevation ofLight:400 ~1350(mm)
3.Indicating Value Error:
   LuminousIntensity: ± 10%
   Optical AxisOffset: ± 35mm/10m
   CentralHeight of Photovoltaic Box:±10mm
4.Measuring Distance:   1m
5.Length of the guide rail: 5m
6.Power Consumption:   200W
7.Weight:             90kg
8.Dimensions:    750mm (Length)×570mm(Width)×1870mm (Height)
9.Package(Crate):900mm (Length)×800mm(Width)×2050mm(Height)
The MQD-3A type forautomatic measurement of motor vehicle headlamp high beam luminous intensity,high beam offset; low beam offset; headlamp benchmark center height of theparameters. Meet GB7258, GB 21861, GB18565-related the headlamp measurement ofthe technical requirements, networking detection applicable to motor vehiclesafety performance and integrated performance test line, the car manufacturer'snew car factory test, as well as motor vehicle maintenance department of motorvehicle maintenance detection .
Using state-of-the-art machine vision and high-speed DSP imageprocessing technology, automatic completion of the headlamp high beam, nearlight the parameters, accurate detection.
Dual CCD technology, independent testing, to adjust motorvehicle headlamp far beam and low beam.
Multi-point auxiliary the searching light system and a specialCCD search light way to ensure the speed of light detection.
Double positioning system, effectively prevent outside lightinterference.
Equipment has the reliable networked software and richcommunication instruction.
Bright digital display system to facilitate the detection linemanual identification.
Devices using the new structure: system drive mechanism usingfree fuel, "zero power" drive and stepless speed design to ensurehigh-speed detection; whole fully enclosed dust-handling realize "zeromaintenance costs.
1.产品使用环境条件:
环境温度:-5°C ~ 40°C
相对湿度:≤90%
电源电压:AC220V ± 10%,50±1Hz
2.测量范围:
a) 发光强度:0 ~ 120000cd
b) 光轴偏移量:
远光:
垂直方向:上400mm/10m~下560mm/10m
水平方向:左560mm/10m ~右560mm/10m
近光:
c) 灯高测量:400 ~1350(mm)
3.示值误差:
a) 发光强度:± 10%
b) 光轴偏移量:± 35mm/10m
c) 光电箱中心高度:±10mm
4.测量距离:1m
5.导轨长度:5m
6.功
耗:
200W
7.重
量:
90kg(主机净重)
8.外形尺寸:750 mm×570 mm×1870mm(宽×深×高)
9. 包装:木箱(8mm板)
包装尺寸:900mm×800mm×2050 mm
产品特点
采用先进的机器视觉和高速DSP图像处理技术,全自动完成前照灯远光、近光各项参数的准确检测。
双CCD技术,独立检测、调整机动车前照灯远光和近光。
多点辅助寻光系统和特殊的CCD寻光方式,确保灯光检测速度。
双重定位系统,有效防止外界光干扰。
联网指令库提供丰富、可靠的通讯软件指令。
采用高亮数码显示系统,方便检测线人工识别。
机身采用新型结构:系统传动机构采用全免加油、“零动力”驱动和无级调速设计,确保高速检测;整机采用全封闭防尘处理,真正实现“零维护成本”。
支持高速检测模式,不支持双灯同检与在线调整技术。
GMT+8, 2026-4-5 21:46
