[色谱/质谱] 购买的标样还需要分析校正吗?
newnoob 发表于 2014-9-18 14:56:32 | 显示全部楼层 |阅读模式
购买的标样,证书提供的含量应该可以直接用。但如ASTM D5599,“before preparing the standards,determine the purity of the oxygenate stocks and make corrections for the impurities found. Whenever possible,use stocks of at least 99.9% purity. Correct for the purity of the components for water content determined by Test method D1744."
为什么?如何矫正?
GMT+8, 2026-4-6 05:13
