[容量] 常用玻璃仪器英文名称
丁香花 发表于 2008-4-6 12:51:40 | 显示全部楼层 |阅读模式
常用玻璃仪器英文名称
adapter 接液管
air condenser 空气冷凝管
beaker 烧杯
boiling flask 烧瓶
boiling flask-3-neck 三口烧瓶
burette clamp 滴定管夹
burette stand 滴定架台
Busher funnel 布氏漏斗
Claisen distilling head 减压蒸馏头
condenser-Allihn type 球型冷凝管
condenser-west tube 直型冷凝管
crucible tongs 坩埚钳
crucible with cover 带盖的坩埚
distilling head 蒸馏头
distilling tube 蒸馏管
Erlenmeyer flask 锥型瓶
evaporating dish (porcelain) 瓷蒸发皿
filter flask(suction flask) 抽滤瓶
florence flask 平底烧瓶
fractionating column 分馏柱
Geiser burette (stopcock) 酸氏滴定管
graduated cylinder 量筒
Hirsch funnel 赫氏漏斗
long-stem funnel 长颈漏斗
medicine dropper 滴管
Mohr burette for use with pinchcock
碱氏滴定管
Mohr measuring pipette 量液管
mortar 研钵
pestle 研杵
pinch clamp 弹簧节流夹
plastic squeeze bottle 塑料洗瓶
reducing bush 大变小转换接头
rubber pipette bulb 吸耳球
screw clamp 螺旋夹
separatory funnel 分液漏斗
stemless funnel 无颈漏斗
test tube holder 试管夹
test tube 试管
Thiele melting point tube 提勒熔点管
transfer pipette 移液管
tripod 三角架
volumetric flask 容量瓶
watch glass 表皿wide-mouth bottle 广口瓶
乔浩 + 2 热心上传!
GMT+8, 2026-4-10 10:04
