[答疑互助] 较差法能不能用计算器算出来呢?
ab200210 发表于 2026-3-6 15:52:43 | 显示全部楼层 |阅读模式
较差法能不能用计算器算出来呢?
123456789011qq 发表于 2026-3-13 10:35:15 | 显示全部楼层
不能吧应该,至少现在的我不会用计算器算较差法
jr17sh 发表于 2026-3-14 11:00:49 | 显示全部楼层
' 窗体控件说明:
' Text1(0)~Text1(n-1):测量值输入文本框数组
' Command1:计算按钮
' Command2:导出报告按钮
' Label2:显示计算结果
' CommonDialog1:保存文件对话框
Option Explicit
Private Sub Command1_Click()
    Dim n As Integer, i As Integer
    Dim sumDiffSq As Double, s As Double
    Dim x() As Double
    ' 获取测量次数(文本框数组元素个数)
    n = Text1.UBound + 1
    If n < 2 Then
        MsgBox "测量次数至少需要2次", vbCritical
        Exit Sub
    End If
    ' 读取输入数据
    ReDim x(0 To n - 1)
    On Error GoTo inputErr
    For i = 0 To n - 1
        x(i) = Val(Text1(i).Text)
    Next
    ' 较差法计算标准偏差
    sumDiffSq = 0
    For i = 0 To n - 2
        sumDiffSq = sumDiffSq + (x(i + 1) - x(i)) ^ 2
    Next
    s = Sqr(sumDiffSq / (2 * (n - 1)))
    ' 显示结果
    Label2.Caption = "单次测量实验标准偏差:s = " & Format(s, "0.0000") & vbCrLf & _
                     "算术平均值标准偏差:s(avg) = " & Format(s / Sqr(n), "0.0000")
    Exit Sub
inputErr:
    MsgBox "第" & i + 1 & "个测量值输入错误,请输入数字", vbCritical
End Sub
' 导出计算报告
Private Sub Command2_Click()
    Dim fso As Object, ts As Object
    Dim savePath As String
    CommonDialog1.Filter = "文本文件(*.txt)|*.txt|所有文件(*.*)|*.*"
    CommonDialog1.ShowSave
    If CommonDialog1.FileName = "" Then Exit Sub
    savePath = CommonDialog1.FileName
    Set fso = CreateObject("Scripting.FileSystemObject")
    Set ts = fso.CreateTextFile(savePath, True)
    ts.WriteLine "计量较差法计算报告"
    ts.WriteLine "生成时间:" & Now
    ts.WriteLine "=============================="
    ts.WriteLine "测量值序列:"
    For i = 0 To n - 1
        ts.WriteLine "x" & i + 1 & " = " & Text1(i).Text
    Next
    ts.WriteLine Label2.Caption
    ts.WriteLine "依据:JJF 1059.1-2012《测量不确定度评定与表示》"
    ts.Close
    MsgBox "报告已导出至:" & savePath, vbInformation
End Sub
' 动态添加测量值输入框
Private Sub Form_Load()
    Dim i As Integer, txt As TextBox
    ' 默认生成10个输入框(可根据需要调整数量)
    For i = 1 To 10
        Set txt = Controls.Add("VB.TextBox", "Text1" & i, Me)
        txt.Index = i - 1
        txt.Left = 100
        txt.Top = 100 + (i - 1) * 400
        txt.Width = 2000
        txt.Height = 300
        txt.Visible = True
        ' 添加标签
        Set lbl = Controls.Add("VB.Label", "Label1" & i, Me)
        lbl.Left = 2200
        lbl.Top = 100 + (i - 1) * 400
        lbl.Width = 1000
        lbl.Height = 300
        lbl.Caption = "测量值" & i
        lbl.Visible = True
    Next
End Sub
用VBA就可以实现了
酒巷清风88 发表于 2026-3-17 11:18:10 | 显示全部楼层
不能,只能按照公式自己计算,计算器中只有贝塞尔公式的
GMT+8, 2026-4-5 07:11
