[坐标] 三坐标测量机误差补偿方法的研究
兑水 发表于 2008-6-8 11:38:13 | 显示全部楼层 |阅读模式
赵天婵[1] 吴晖[1] 冯俊[1] 吴文炳[2]
[1]江汉大学机电学院,武汉430056 [2]北京南航立科机械有限公司,北京100076
摘 要:通过对三坐标测量机更换测量系统,改进、设计与此相配的机械部分,从而建立误差补偿模型,并进行误差测试,同时利用软件进行误差补偿。结果证明:本误差补偿方法能使测量机的空间精度提高2—3倍,且这种补偿方法简单可靠,为通过误差补偿提高三坐标测量机的精度提供了简单而有效的手段。[著者文摘]
Error Compensation to Three Coordinate Measuring MachineZHAO Tianehan , WU Hui , FENG Jun , WU Wenbing 1. Eleetromeehanieal School, Jianghan University, Wuhan 430056, China; 2. Beijing Nanhanglike Mechanic Co, Ltd, Beijing 100076, ChinaAbstract:Some modification to the three coordinate measuring machinec (CMM), was accomplished with changing the measuring system and modifying the corresponding mechanical parts. A better error compensation model was constructed which applied software to measure the error. As a result, it increases the volumetric accuracy by 2 or 3 times. The method is convenient and reliable to improve the accuracy of the CMM through the error compensation.[著者文摘]
Key words:CMM; Error compensation; Error analyzing; Grating scale
三坐标测量机误差补偿方法的研究.pdf
139.79 KB, 下载次数: 36, 下载积分: 金币 -1
GMT+8, 2026-4-9 21:49
