[工程参量] 免费的pc-dmis快捷键,看到有人发了个收钱的不爽
dingping 发表于 2008-7-31 21:42:39 | 显示全部楼层 |阅读模式
Ctrl + Y
Executes program from a specified location.
Ctrl + Z
Scale to fit (graphics window).
Alt + -
Deletes last hit.
Alt + F3
Displays edit window search box.
Alt + Z
DCC mode.
Ctrl + Alt + A
Displays the alignment utility box.
Ctrl + Alt + P
Displays the probe utility box.
Ctrl + End
Takes you to the end of the program.
Ctrl + Home
Takes you to the beginning of the program.
F1
Help.
F2
Displays the expression builder box.
F3
Mark/Unmark toggle.
F4
Prints the edit window.
F5
Displays the setup options dialog box.
F6
Displays the font selection box.
F7
Toggle fields.
F8
Toggle backward.
F9
Displays the feature dialog box.
F10
Displays the parameters options box.
Shift + F3
Will mark all.
Shift + F10
Displays the jump box.
小钰 发表于 2008-8-2 11:55:08 | 显示全部楼层
还有
Ctrl+E 单步特征运行
Ctrl+U 从光标处开始运行
Ctrl+L 选定的块运行
GMT+8, 2026-4-9 21:50
