[光谱/光度] 火焰原子吸收分光光度法测定土壤中铜元素的不确定度分析
上帝 发表于 2008-8-25 22:11:10 | 显示全部楼层 |阅读模式
沈荣蓉 陈志翔 沙悦韬
上海市卢湾区环境监测站,上海200020
摘 要:对原子吸收分光光度法测定土壤中铜元素含量的不确定度进行评定,分析其不确定度的主要影响因素。结果表明影响其测量不确定度的主要原因是由标准溶液引入的不确定度、标准曲线引入的不确定度和重复测量引入的不确定度。[著者文摘]
Uncertainty of Determination Copper in Soil with Flame Atomic Absorption SpectrometrySHEN Rong-rong, CHEN Zhi-xiang, SHA Yue-taoShanghai Luwan Environmental Monitoring Station, Shanghai 200020, ChinaAbstract:The determination of uncertainty of copper ion in soil using flame atomic absortion spectrophotometry was introduced.The determination uncertainty of copper ion in soil mainly came from the standard solution,the labor curve and the repetitive measurement.[著者文摘]
Key words:atomic absorption spectrometry; soil; copper; uncertainty
火焰原子吸收分光光度法测定土壤中铜元素的不确定度分析.pdf
131.93 KB, 下载次数: 27, 下载积分: 金币 -1
GMT+8, 2026-4-6 22:06
