[工程参量] 圆度误差评定的曲率法研究
飘八零 发表于 2008-10-15 21:15:31 | 显示全部楼层 |阅读模式
李秀明
石照耀
北京工业大学机械工程与应用电子技术学院,北京100022
摘 要:提出了基于曲率的圆度误差评定方法。从曲率的定义出发,推导出了用最大内接圆或最小外接圆评定圆度误差时筛选点的条件:用最大内接圆评定时,筛选掉曲率半径最小的点;用最小外接圆评定时,筛选掉曲率半径最大的点。根据这一条件,可以得到满足圆度误差评定原则的3个特征点,从而确定圆度误差。筛选点时,用最小二乘圆把测量点分成内点集合和外点集合,最大内接圆从内点集合中筛选,最小外接圆从外点集合中筛选,这样就可大大减少了计算量。经过实例验证,表明该方法的正确性和可行性。[著者文摘]
An Evaluation Method for the Roundness Error Based on CurvatureLI Xiu-ming, SHI Zhao-yao College of Mechanical Engineering and Applied Electronics Technology, Beijing University of Technology, Beijing 100022, ChinaAbstract:A novel method for evaluation of the roundness error based on curvature is presented. The condition for choosing points is derived from the definition of the curvature in evaluating the roundness error with maximum inscribed circle or minimum circumscribed circle. The points with the least radius of curvature are eliminated with maximum inscribed circle, whereas the points with the largest radius of curvature are eliminated with minimum circumscribed circle. According to the above condition three points satisfying with the criterion for evaluation of the roundness error are discovered, so the roundness error is determined, The points are divided into outer points and inter points according to the least square mean circle in order to reduce the amount of computation. The points are eliminated from internal points for maximum inscribed circle, but for minimum circumscribed the points are chosen from external points. The correctness and the feasibility of the method are proved through an example.[著者文摘]
Key words:Metrology; Roundness error; Curvature; Maximum inscribed circle; Minimum circumscribed circle
圆度误差评定的曲率法研究.rar
130.44 KB, 下载次数: 19, 下载积分: 金币 -1
karotzhc 发表于 2009-10-12 22:28:47 | 显示全部楼层
感谢LZ的无私奉献啊!!!
桃李满天下 发表于 2009-10-15 19:15:12 | 显示全部楼层
太感谢啦,
GMT+8, 2026-4-7 11:10
