[工程参量] 平面度和直线度误差的快速评定——增量算法
飘八零 发表于 2008-10-15 21:25:41 | 显示全部楼层 |阅读模式
岳武陵
吴勇
南通大学机械工程学院,江苏南通226007
摘 要:在平面度(直线度)误差评定的最小包容区域法中,提出一个新的、快速的实施方法——增量算法。该法以计算几何中凸壳的理论为依据,结合平面度(直线度)误差评定中数据的特点,从4个(3个)测点的子集开始,通过评定子集的平面度(直线度)以及增加距子集包容面最远的点构成新的子集的方法,逐步逼近精确解。该算法单调递增收敛到精确解,时间复杂度为O(n1)。几个算例证实了方法和结论的正确性。[著者文摘]
A Fast Evaluation Method for Flatness and Straightness Tolerance by Means of Incremental AlgorithmYUE Wu-ling, WU Yong College of Mechanical Engineering, Nantong University, Nantong, Jiangsu 226007, ChinaAbstract:A fast and accurate method called incremental algorithm is proposed to implement the minimum zone tolerance for evaluating flatness or straightness errors. The algorithm is based on the convex - hull theory in computational geometry and also explores the properties of the measurement data. The algorithm starts from a subset with four (three) measurement points. If the bounding flats or straights determined by current subset can cover the whole remaining set, the distance between the bounding planes (lines) is the final accurate flatness (straightness). Otherwise, put the point with maximum distance from the bounding planes into current subset, and repeat the previous step for the new subset. It is proved that the sequence of flatness (straightness) of these subsets monotonously increasingly converges to the accurate result. The timing complexity is only O (n1). Several examples verify the correctness of this algorithm.[著者文摘]
Key words:Metrology ; Tolerance evaluation; Flatness ; Straightness ; Minimum zone ; Incremental algorithm
平面度和直线度误差的快速评定——增量算法.rar
214.14 KB, 下载次数: 60, 下载积分: 金币 -1
sssssq 发表于 2009-2-16 22:17:19 | 显示全部楼层
可否考多个项目检定员证?
可否考多个项目检鉴定员证?如没有某个项目检定员证,那可不可以从事这项目的检定?
zhangliang2 发表于 2009-9-20 16:24:52 | 显示全部楼层
工厂一般采用对角线法,只有在有争议的情况下才采用最小区域法。
spriver 发表于 2009-10-1 00:34:27 | 显示全部楼层
当然可以考多个项目的,如果没某个项目的检定员证,应该是不可以签字的
GMT+8, 2026-4-7 13:00
