[多功能仪器] 数字多用表FLUKE8840/8842怎样修正示值误差
一可 发表于 2008-10-23 22:47:10 | 显示全部楼层 |阅读模式
数字多用表FLUKE8840/8842怎样修正示值误差啊,我参考的是FLUKE的使用手册,没有维修手册怎么办
[ 本帖最后由 vandyke 于 2008-10-23 23:00 编辑 ]
 楼主| 一可 发表于 2008-10-23 22:48:31 | 显示全部楼层
怎样不开盖用标准源修正呢
swife 发表于 2008-10-24 00:32:20 | 显示全部楼层
参考说明书的操作,没有的话向办事处的人咨询,可以进入它的校准模式进行校准
黎明 发表于 2008-12-11 19:11:27 | 显示全部楼层
打电话打FLUKE公司问一下啊!
gaobingic 发表于 2008-12-11 20:22:06 | 显示全部楼层
好好看看Fluke8845/8846校准手册的3-25页一下介绍!
Adjustment (Calibration)
Meter adjustments, or calibration, should be performed at the desired interval, or
whenever a verification test indicates a Meter function is out of tolerance. The Meter
accuracy will stay within specifications only if the adjustment procedure is performed at
regular intervals. A one-year interval is adequate for most applications. The Meter’s
accuracy specifications are not valid beyond the one-year interval.
Meter adjustments are accessed only through the remote interface with a series of
adjustment steps. The remote program directs the test equipment to apply a series of
shorts, opens, voltages, currents, and capacitance (8846A only) to the Meter. At each
step, the Meter internally makes the necessary adjustment to bring the Meter into
specification. No internal mechanical adjustments are necessary.
Using an automated, computer-controlled procedure, the calibration and verification
procedures can be performed on the Meter in under 60 minutes. A sample adjustment
program is listed on the “Sample Adjustment Program” section later in this manual. A
MetCal program is available at www.fluke.com to adjust the Meter.
The Meter’s adjustments are password protected to prevent accidental or unauthorized
adjustments. The security password must be entered through the front panel or remote
interface before adjustments can be made to the Meter.
Unlocking the Meter for Front-Panel Adjustments (Calibration)
To unlock the Meter for adjustments from the front panel:
1. Press I.
2. Press CAL.
3. Press UNLOCK CAL.
Press the soft key labeled -- to decrement the character or ++ to increment the
character. The character can be set to 0 through 9, A through Z, period (.), and
dash (-).
To move to the next character, press -->.
4. Press ENTER to enter the password and unlock the Meter for adjustments.
Find the CALIBRATION:SECURE:STATE command in the “Supported SCPI
Commands” section of the 8846A/8845A Programmers Manual for information on
unlocking the Meter for calibration.
The Meter is shipped from the factory with the password set to FLUKE884X.
何必 发表于 2008-12-11 21:28:23 | 显示全部楼层
请问5#  gaobingic:
Fluke8845A/8846A是不是需要通过MET/CAL才能调校?
请问你有在MET/CAL上运行的Fluke8845/8846调校程序么??
能不能给我一份啊!!
谢谢!!
[ 本帖最后由 何必 于 2008-12-11 21:37 编辑 ]
gaobingic 发表于 2008-12-12 11:07:51 | 显示全部楼层
不需要!可以手动外校准!~
不需要!可以手动外校准!~
要有高准确度标准源,充分预热!
[ 本帖最后由 gaobingic 于 2008-12-12 11:11 编辑 ]
huwenjing 发表于 2008-12-12 18:48:43 | 显示全部楼层
可以外部校准,仪器面板上有一孔,可以通过他设置为校准状态
何必 发表于 2008-12-12 22:03:46 | 显示全部楼层
谢谢!!
我们有5720A  、5700。
那个孔在前面板还是后面板阿??
不开盖能看得见么??
[ 本帖最后由 何必 于 2008-12-12 22:17 编辑 ]
huwenjing 发表于 2008-12-12 22:06:57 | 显示全部楼层
在前面板,就是显示屏右下角处
何必 发表于 2008-12-15 12:31:49 | 显示全部楼层
楼上两位大虾,会不会你们看错了
我问的是8845A/8846A ,而不是8840/8842
FLUKE的8845A/8846A 你们亲手调校过没有啊??
在显示屏幕右下角我根本就找不到有什么孔。
后来打电话咨询fluke的技术人员,他们说现在还只能通过MET/CAL软件校准
手动校准他们工厂还没发不出来呢
计量匠 发表于 2008-12-18 20:24:09 | 显示全部楼层
回复 11# 何必 的帖子
不要听FLUKE公司胡说只有他们的软件能校准!这个通过手动操作前面板就可以调整得几乎跟标准输出值一样,我自己编的数字多用表自动校准/检定系统也 可以实现全自动调整(校准)。好多年不做数表计量了,所以,现在也没有记住调整步骤了,明天告诉你!
我开发的“数字多用表自动校准/检定系统”可以自动校准(调整)和检定几乎所有国外常见数表以及手持式万用表,FLUKE公司的销售在我面前从来不提他们的那套计量软件,呵呵。周围不少国防计量单位都买了我的这套软件,需要的话可以跟我联系!
[ 本帖最后由 计量匠 于 2008-12-18 21:09 编辑 ]
何必 发表于 2008-12-18 21:14:35 | 显示全部楼层
回复 12# 计量匠 的帖子
谢谢!最近8846A/8845A这两款数表折磨了我好久。期待计量匠大虾的指导!!
计量匠 发表于 2008-12-19 22:16:50 | 显示全部楼层
8840A的校准(调整)步骤
8840A的校准(调整)步骤如下:
        1  打开校准开关(前面板右下小孔中)后,用STORE键触发显示00.0,开始校准
        2  根据显示依次校准码权,DCV满度
        3  换至ACV档开始校准交流电压,从10mV@1kHz依次校准ACV低频
        4  校准电流,依次校准直流和交流,交流在1000mA@400Hz点校准
        5  校准电阻:先校准100Ω,按下OFFSET键,用对应位按键键入将输入的标准电阻值,再按下STORE键。依次校准至10MΩ
另,8845A/8846A的校准步骤可以在fluke网站上找到
何必 发表于 2008-12-19 22:31:24 | 显示全部楼层
回复 14# 计量匠 的帖子
8845A/8846A的校准步骤是可以在fluke网站上找到
关键是8846A的前面板右下角处只有一个USB接口,根本就没有什么小孔(校准开关)
而8845A前面板右下角处连USB接口都没有。
可能与8840A有所不同吧??
计量匠大虾,你能再帮我确认一下么??
[ 本帖最后由 何必 于 2008-12-19 22:32 编辑 ]
何必 发表于 2008-12-23 12:47:00 | 显示全部楼层
最近向fluke要了8845a/8846a在metcal软件上运行的校准及调校程序,该程序需要met/cal是7.2的版本才能运行,有需要我可以给大家。
huwenjing 发表于 2008-12-23 19:55:56 | 显示全部楼层
回复 15# 何必 的帖子
在Fluke网站上下载8845A/8846A校准手册,在P3-27有校准步骤
何必 发表于 2008-12-23 20:55:38 | 显示全部楼层
回复 17# huwenjing 的帖子
校准手册上是有校准步骤的,不过如果你亲手去调校的时候,你就会明白我的意思的。
huwenjing 发表于 2008-12-24 12:44:06 | 显示全部楼层
不明白你什么意思?
何必 发表于 2008-12-24 15:18:36 | 显示全部楼层
回复 19# huwenjing 的帖子
我的意思是如果你亲自去调校的时候,你就会发现当你进入校准菜单,输入校准密码以后,8846A的前面板就失效了,根本无法按照校准手册的步骤进行下去。
呵呵!!
跟8842是不一样的
szcatciliu 发表于 2008-12-24 16:04:13 | 显示全部楼层
只有用软件对其进行调整!现在大家有点店大欺客感觉吧!FLUKE最近推出的数字多用表指标都不错,不过质量不如以前,调校也比较麻烦,不知大家是否这种感觉?
OUYANGGANG 发表于 2009-4-11 23:15:10 | 显示全部楼层
前面的仁兄都是在给你说8840/8842的校准经验,他们都没有对8845A/8846A作过校准工作,是老经验咯。
我也问过Fluke的人,不能手动调整,要开盖,但自己开盖后就不会进行免责保修啦,视为非法开机。呵呵!
有什么问题厂家是不保修的。软件调整需要买他们的7.0以上的版本。我们本来有老版本metcal6.0,但不能免费升级到7.0以上。真的是店大欺人。
李逍遥 发表于 2009-4-12 22:00:26 | 显示全部楼层
用小改锥按下前面板显示屏右下角小孔内的CAL按钮,可以按提示步骤进行校准,也可以选择功能、选择量程校准
李逍遥 发表于 2009-4-12 22:01:27 | 显示全部楼层
5700或5720A校准8840完全足够了!
XUXINXUEXI 发表于 2009-4-25 15:08:53 | 显示全部楼层
版主自己开发了数表的自动校准系统,不知道硬件软件是如何配置的??通用性怎么样??
GMT+8, 2026-4-6 04:58
