[色度] 关于光源颜色温度标定方法的讨论
飘八零 发表于 2008-11-27 23:12:52 | 显示全部楼层 |阅读模式
刘慧 肖文宾
中国计量科学研究院,北京100013
摘 要:本文介绍了我国颜色温度的量值复现方法,着重讨论将颜色温度副基准灯的量值如何准确传递给各种传递标准灯的方法,并阐述了各种方法的特点,通过实验数据验证了对环型灯丝的待测灯在积分球中使用时,通过多点标定其颜色温度,取平均值作为测量结果的方法。[著者文摘]
Discussion on the Color Temperature Calibrated Method of Light SourceLiu Hui ,Xiao Wenbing National Institute of Metrology, Bering 100013Abstract:The method of realization of the national primary unit of color temperature was introduced at this paper, How to transfer the unit value from primary standard lamp to other standard lamp was also discussed, the advantage and disadvantage of each method was analyzed. A group of experiment data was given as an example.[著者文摘]
Key words:Color temperature ; Standard lamp
关于光源颜色温度标定方法的讨论.pdf
158.64 KB, 下载次数: 45, 下载积分: 金币 -1
Rie + 2 技术资料
蓝色经典 发表于 2008-12-1 17:40:17 | 显示全部楼层
不错,现在标准光源好难买到,稳定性,年变化量都不是很理想
GMT+8, 2026-4-6 03:07
