[工程参量] C#二次开发连接pc-dmis代码
huangwang 发表于 2024-10-9 11:50:21 | 显示全部楼层 |阅读模式
using PCDLRN;
namespace PCDMIS
    internal static class ConnectPcDMIS
        public static Application? Application;
        public static PartProgram? PartProgram;
        public static Commands? Commands;
        public static bool PCdmisState;
        public static Commands? GetCommands()
            Type? comType = null;
            object? comObj = null;
            try
                comType = Type.GetTypeFromProgID("PCDLRN.Application");
                //从进程中获取正在运行的PCDMIS程序
                comObj = Activator.CreateInstance(comType);
                //创建一个实例。
                Application = comObj as PCDLRN.Application;
                //将这个实例强制转换成 PCDMIS的Application对象。
                PartProgram = Application.ActivePartProgram;
                //获取到Application对象当前处于激活状态的 PartProgram对象。
                if (PartProgram != null)
                    //如果PartProgram对象不为空。
                    Commands = PartProgram.Commands;
                    //获取到Commands对象。
                    // Debug.WriteLine(Commands.Count);
                    PCdmisState = true;
                else
                    PCdmisState = false;
                    return null;
            catch (System.Exception em)
                return null;
            return Commands;
GMT+8, 2026-1-1 12:28
© 2001-2025 Discuz! Team.
